P
o While steel drive shafts from other RMK models may fit, Polaris does not recommend this because there is a risk of the shaft seizing on to the inner bearing race and lower drive sprocket.
Anybody have any insight why this might happen?
My guess is that if everyone is installing the 2012 steel shaft in their sleds that will make polaris look bad, so hence they put something stupid like this in the bulletin. try to get people to believe that this 3 piece aluminum shaft is the greatest invention ever. the 2005,2011,2012 shaft has a big oil seal collar on it to back up the bearing, there is no way the bearing is going to seize to it. and the belt pulley has a steel insert with splines molded in where it slides on the shaft, just like a chaincase gear. steel on steel.....its been done this way for 30+ years in snowmobiles. a chaincase does have oil in it, but if anyone is worried....put a dab of anti-seize and smear it on the surface....problem solved.
