BELLOW IS THE BASIC SPEC INCLUDING ALL OPTIONS REQUESTED;
Link to 2017 Logan Trailer walk through:
www.youtube.com/watch?v=QhxJWAi2XKs
Logan 35’ GN
General-
35’ Box
102” OD / 98.5 ID
88” Inside Height
Axles forward 18”
Gray/Black
Wheels/Axles-
• 8K Dexter Torflex oil bath axles
• 235/85/16 Goodyear Tires or equivalent
• Aluminum/Black Wheels
Exterior/Electrical-
• .050 Aluminum VHB (Charcoal Gray)
• Vortex rubber coat under GN
• Two (2) 37” man Doors with windows (Left side mounted between axles, right side mounted at front of box) Both with 12” LED flood mounted above)
• Right hand man door keyed with keyless entry pad
• One (1) window on each side of GN to be mounted as high as possible
• Two (2) windows in main box of trailer (Left side window mounted between man door and fold down side access door, Right side mounted rear of storage boxes & window in each man door.
• All windows frameless style
• 18” Treadbrite (Black)
• Angled front slide ramp with Three (3) 12” LED flood mounted above (Light switch mounted exterior at slide ramp or in fuel compartment)
• Rear Ramp with Three (3) 12” LED flood mounted above (wired for switch & Reverse)(light switch mounted exterior at rear door)
• Dedicated LED backing lights
• 12” LED floods mounted left & right at axles, wired to back up lights for side illumination
• Two (2) Max Air Electric Roof Vents with 12v electric fan’s and black Maxx 2 Vent Covers
• Two (2) #30 Propane tanks
• Locking roll up front GN enclosure with LED interior lights, propane storage (mounted high on left), spare tire storage (mounted low on right), battery storage for Three (3) deep cycle 750 min or two (2) 6v deep cycle (mounted above spare tire , storage for Honda EU2000i under propane (reinforce bottom pan), storage for tire chains
• Fuel station- fuel tank gauge, 10’ of ¾” hose, pump, filter & nozzle.
• LED marker lights (8ea. side of top rail box (every 4’), 3ea. side tapered GN, 3 front of neck , 2 ea. side low front/rear of axles
• Single electric/hydraulic jack
• Ladder to access roof for snow removal with overhead interior storage mount. Mount location storage area in neck.
Interior/Electrical
• Aluminum lined walls and ceiling (insulated)
• Insulated floors
• Heated floors ducted for left & right side under hooks, NO center heat (If possible, plumb to rear of trailer)
• One (1) table 27”x48” mounted left side 48” rear of man door (top of table in closed position should be within 1” or less of storage hooks)
• One (1) table 27”x60” mounted right side 14” rear of man door (top of table in closed position should be within 1” or less of storage hooks)
• 1 TV swivel mount with 120v power and HDMI/RCA cables. Mounted on left side forward of slide ramp. Retainer strap to be installed to prevent TV from moving in transport.
• LED interior lights seven (8) each side total of fourteen (16) + one (1) each side in GN loft area Total two (2) Total of 18 interior LED lights
• 9’ aluminum oil storage trough mounted 16” below ceiling with hooks mounted underneath running length of left side trailer (where applicable) (maximize box length to run from rear bench to rear of trailer)
• 24’ Aluminum helmet/gear storage cabinet’s w/hyd strut support mounted right side. 4’ box-12’ open storage-4’box-4’box. Stereo deck mounted forward of storage box’s, large cubby area above or below deck with three (3) 12v/USB plugs, sub-woofer mounted in neck behind wardrobe closet on right side wall. (Stereo equip to be provided by customer)
• Six (6) USB/12V plugs & one (1) 120v outlet mounted in front section of 12’ open storage area
• One (1) 120v outlet in each enclosed 4’ storage box
• Wardrobe closet mounted above 40K heater (shortened to accommodate aux heater above)
• Wardrobe closet with drying racks full height.
• All closet doors to have hyd strut installed (wardrobe, boot box, front storage box, side storage boxes)
• Stereo- Qty-8 5.25” speakers, Qty-1 12” subwoofer, Qty-1 Stereo Deck, Qty-1 4 channel amplifier
• Minimum 40k BTU forced air heater to be mounted in standard configuration
• Aux heater 75k mounted above wardrobe closet on far-right side. If possible, notch tapered tapper at top of wall to allow heater to be mounted flush with wall. This will allow full height heated drying racks to the left. Sheet any exposed area with matching aluminum face plate. Please advise
• Honeywell Programmable thermostats
• Double Boot dryers
• Delete one (1) 40K heat duct to main trailer and plumb for two (2) heat ducts into wardrobe closet
• Four (4) fold up benches vertically mounted (3- forward of left man door, 1- rear of left man door)
• One (1) 120v outlet mounted center of trailer on left & right side 12-18” above floor (total of 2)
• One (1) 120v outlet mounted forward each side of GN (Total of 2)
• One (1) 120V Outlet mounted in GN behind wardrobe closet
• One (1) 120v outlet mounted rear of trailer left & right side 12-18” above floor (total of 2)
• 120v AC unit WITH HEAT STRIP (LOW PROFILE) roof mounted center or forward with Black AC roof cover
• Twelve (12) HD surface mount tie downs OR alternate cargo strapping down interior walls.
• One (1) sled lift 16” back of boot box
• One (1) center point sled lift approximately 160” back of boot box
• One (1) rear sled lift approximately 265” back of boot box
• Carpet on GN drop wall & deck
• TV mount w/120v plug, two (2) HDMI & one (1) set RCA’s wired mounted forward of left side slide door
• One (1) HDMI connected to DVD player, One (1) HDMI to outlet above front table on right hand side
• RCA’s connected to deck
• DVD player mounted below stereo deck with cubby cut out of wood face
• One (1) 120v plug mounted above table on right side with HDMI
• Cover over fuse box, no vents in location of ski contact
• Rubber Vortex lined floors
• Led light behind hitch to illuminate loading
• One (1) snow shovel & Broom mount – Location between rear door and oil storage box
• One (1) backboard mount – Behind 10’ open storage or above double 4’ box
• Inverter/converter combo with shore line power (inverter large enough to power TV & 120v heater fan)
• Storage cabinet at front of gooseneck with Aluminum false wall with one carpeted shelf running length with led light (doors 34” tall x 30” wide)
• Cup holders mounted 50” or above from floor, two (2) between each sitting bench, several down right side (each holder should have two (2) cup holder spots)
• Hooks under storage cabinets entire right side
• Hooks under storage cabinet & above benches entire left side
• Caliber Products full guide kit
Fuel Tanks-
• Two (2) fuel tanks with divider valve for multiple fuels (aviation/race & pump 91)
• One (1) lighted Fuel gauge
• One (1) spin on fuel filter
• One 20’ hose and nozzle
