Well if they can't then I guess a giant wrap is in your very near future.
CHA-CHING! $$$$$$$$$$$$$
Note: this_feature_currently_may_not_be_available_in_some_browsers
2. Heater Thermometer
For the most part it was really little more than an ON-OFF switch.
When it was cold, you wanted the heater ON pretty much all the time.
The trailer, even with insulation, really isn't able to retain much heat when the heater goes off, so I am not sure the thermometer ever really turned "off" the heater during the winter.
Message sent to Mirage
Thermometer really didn't work very well, the slide didn't want to hold any particular temperature setting on the low side.
It was basically either ON high or off.
Out of my league for a sled trailer.If you wanted the ULTIMATE heating system for your More-Perfect trailer.
A propane fired compact liquid heater with VIEGA CLIMATE PANELS would be the way to go.
Heat from the ground up... super efficient.
I know it is a dream system... But I've installed it in small boats though.
for a t-stat i put a decent programmable home unit it. works so much better. nice thing about it; you can program it to come on to say 60deg around 3:00 if you think you'll be back to the truck around 3:30 or 4. then when you get there crank it up to 70 and it will only take a few minutes to get up to temp.
one thing ive really been pondering:
what about a flat nose bumper pull trailer????
Small rubber mallet to knock the ice off of the sleds before loading them in the trailer is a massive help to prevent lots of ice inside. We also keep a broom in the trailer to sweep it out.
I like this for a tie down track and I leave several of the rings in different spots for my tiedowns and "traction"
http://www.towrax.com/product.phtml?p=25&cat_key=7
These rings work well with the super clamps also.
http://www.towrax.com/product.phtml?p=23&cat_key=7
christopher - Why not a gooseneck? Does mirage not make one?
4. Better Stereo
My Number one user comment
Without a doubt, one of the most FUN features of the trailer was the sound system. Who would have thought that playing some tunes before and after the ride would be SO DANG NICE. Talk about setting the "Tone" for the day's ride. The inside speakers rocked the trailer all winter long, and come Spring the outside speaker picked up the slack and lit up all the area around the trailer for lakeside parties. Absolutely LOVED having sound!
BUT.
There were some serious shortfalls on the road to acoustic nirvana..
1. This is a LOOONG trailer.
With a pair of speakers in the front and a pair in the rear, the middle had a huge difference in volume that either of the ends. Trailer needs at least 6 speakers inside of it to cover all the square footage.
2. As much as it needed "more" speakers" I think it needed BETTER speakers as well. My last job was manufacturing performance lake boats, and sound systems was one of the things all of my customers DEMANDED, as tunes on the lake were an absolute necessity. So I have a little background in wet environment sound systems. This trailer needs some upgrade marine 3 way speakers. That would hugely change the overall quality of the sound. BUT, the skin/walls of the trailer, even with being insulated are VERY thin. So I am not sure there is a way to mount a cone based speaker IN the ceiling. My guess is that we will need to hang the speakers in enclosures and let them be exposed in some manner.
3. Because we are dealing with a trailer, the inside is SUPER reflective. There is just nothing to deaden the sound waves from bouncing off every hard flat surface. With that in mind I felt that 1-2 small subs, mounted inside of the cabinets in the very front and very rear of the trailer would add a tremendous amount of "quality" to the over all sound.
4. The trailer came with an acceptable stereo head unit, but it was nothing to write home about. I would like to seriously upgrade this to something MUCH more cutting edge and feature rich. At the very least we desperately needed a multichannel head so we could isolate the inside sound from the outside sound.
a. 6 speakers instead of 4
b. High quality speakers and a sub woofer
c. Couple 3 way speakers
d. Better head unit
So the stereo was a mixed blessing.
We LOVED having music in the trailer, made the trailer user experience MUCH more fun! We didn't love the way it sounded.
With the speakers in the front and the rear the sound dispersion was very poor. Very loud in front and rear, kinda dead in the middle There needs to be a 3rd set of speakers in the MIDDLE of the trailer to balance out the sound from front to rear.
The speakers in the trailer sound "Tinny", they are shallow and without a well rounded sound. What would be REALLY nice are some higher quality 3-way marine speakers. (and I fully understand the size limitations you are working with in the ceiling mounted speakers)
One thought we had was to add a small sub woofer inside of one of the storage cabinets at the front and rear of the trailer to overcome the shallow speakers mounted inside the roof.
If we can't mount better larger speakers because of depth limitations, then perhaps a small 6-8" woofer mounted in the cabinet facing down would do the trick.?
We also needed a 2 channel speaker control so that the Inside Speakers could be isolated from the Outside speakers. Channel A and channel B. Lots of times we want to crank up the OUTSIDE speakers, which made it impossible to be inside the trailer.
Likewise, better outside speakers would be Greatly Appreciated by the crowd. People absolutely LOVED having sound on the outside of the trailer! Who would have guessed how nice that was.
In general we found the head unit to be less than desirable.
Would really prefer to have a better overall unit to work with.
Found it a real pain to use the Blue Tooth link as that was THE primary way we brought sound into the trailer. Would just like something a little nicer, more modern, better looking and more user (technology) friendly in general.
Ya, not willing to give up the truck bed for daily cargo hauling
