Skinz SPG Question
A
acutah
646
289
Kaysville, UT
I recently sent my front end from my 09 in to have the heim joints beefed up. I have spindles stiill from a 2010 that I sold.
Is there any benefit to using the 2010 (updated) spindles over the 2009? Maybe the SPG kit for 09 is different from 2010 so it won't work anyway.
I tried to call Skinz 3 times today but they never answered.
Anyone have any idea?
A
acutah
646
289
Kaysville, UT
I'm sure they are busy. I was just hoping someone out there might know the answer so I can get this sled buttoned up tonight.
OFT Racing
448
181
Anchorage, AK
www.OFTRacing.com
You can run either, I run the 08 spindles on mine. The only problem is the tie rods are a little short on the 08 spindles. You gain a little trail with the newer spindles, but with the increased performance of the Skinz front end I have never found the Trail to be necessary.
Rick Coffman
OFT Racing
P
pylon
473
88
in the triple slide
they will work yes . the newer spindles just have the tie rod tab centered where the older ones are off set to the out side .
