Any recommendations for handle bars
Elkaholic4life
Twin Peaks
7,492
5,309
Portland, OR
I have a 2013 Pro RMK (rode for 3 years) and a 2018 AXYS. (rode 400 miles last season) Both have the high protaper bars. I know I'd like them 1 1/2 to 2" lower but I think the backwards sweep is part of what i don't like also. I'm just not sure.
Any of you guys tried different bars? Any recommendations or thoughts?
FatDogX
3,307
1,578
ND
The Next Level Fly bars are a little shorter and have a little less pull back in them. I've run them on the last two sleds with good luck. If you do a search on here, there is thread with the break down on the their measurements and shows the difference between Fly bars and Pro Tapers.
Sheetmetalfab
7,908
6,658
The pro bars and axys bars have different sweep.
Which one don’t you like?
I run the medium axys bars and like them much better than the high pro bars.
Apples / oranges
m1kflyingtiger
1,045
481
83
Soldotna, AK
I second this. Have them on my ‘13 pro and absolutely love them.
GoBigParts
4,078
917
Michigan
www.gobigparts.com
Fly NXT LVL.
https://www.gobigparts.com/NXT-LVL-HANDLEBAR-FLY-RACING.html
DDECKER
4,770
1,780
CRAIG COLORADO
Check out RSI
H
Hansen13
164
21
18
31
Cranbrook, BC, Canada
I took my stock bars and cut them 2" narrower and adjusted the lay in them and had them welded together. Couldn't believe the difference it made! I prepped everything and had it ready went to a welding shop and they did the welding for me. Bars are nice and straight, the narrower width makes it a little nicer on your shoulders and easy to dump the sled.
Sheetmetalfab
7,908
6,658
Just wait till that bar snaps off in your hand.
Tempered aluminum handlebars lose 70% of their strength when welded.
(That’s assuming they are 6061-T6)
If they are 7071 or 7075 they won’t even have that much strength.
kanedog
Undefeated mountain clutching champ of the world.
3,106
3,859
I think you would like Fabcraft bars. 5 degree pullback and 5 degree up angle. After 100's of trial and errors, these are the best angles they found.
I ran the pro tapers and they felt a little "off" if that makes sense. Fabcraft feels natural when you get on the sled.
Sent from my SM-G920W8 using Tapatalk
Elkaholic4life
Twin Peaks
7,492
5,309
Portland, OR
Sheetmetalfab Quote:
<table width="100%" cellspacing="0" cellpadding="10" border="0"> <tbody><tr> <td class="alt2" style="border:1px inset"> Originally Posted by Elkaholic4life
</td> </tr> </tbody></table>
Apples / oranges
I don't like ether of them. I know they look a little different but feel the same to me. I just went and measured both because you got me thinking. I used a strait edge, protractor and tape measure.
Pro bars
7 5/8" high
OAL 30 1/2" wide
Between grips 19 3/4"
Up sweep 7 degrees
back sweep 13 degrees
Axys bars
7 3/8" high
OAL 30" wide
Between grips 19 1/2"
up sweep 5 degrees
Back sweep 13 degrees
Elkaholic4life
Twin Peaks
7,492
5,309
Portland, OR
Do you really expect me to take advice from the resident jackass? :face-icon-small-ton
I looked them up. There website sucks and mostly disabled and I think there moving to a new shop.
Thanks you for the info and your input though
Sheetmetalfab
7,908
6,658
Apples / oranges
Pro bars
7 5/8" high
OAL 30 1/2" wide
Up sweep 7 degrees
Axys bars
7 3/8" high
OAL 30" wide
up sweep 5 degrees
I didn’t realize they were such a close match.
It must be the 1” lower that works for me.
Maybe buy a bag of skillz to go with the bars. ????
