Dealer Prep on Pro RMK
mud99
214
107
Truckee, CA
Does anyone know what kind of prep work the dealer does on a Pro RMK?
Picked up my snowcheck a week ago, found the handlebars misadjusted and tightened up wrong, scratchers still tied up, very little oil in the tank, 1/2 gal fuel in the tank at the most.
I'd like to go through the sled and make sure they did the prep work correctly, it seems like they did a rush job.
snowman80
425
210
ND
When we set one up we adjust the handlebars to the middle of the adjustment lines (fine adjustment is done by the customer because we don't know exactly how every customer likes their bars), fill the oil tank full, premix 2.5 gallons of gas for each sled, check track alignment and tension, we leave the scratchers zip tied to the rails so they don't come unhooked and get bent, this year we are leaving the foam on the outside edge of the running boards so they don't wear through your cover, put the windshield on, clean the film off the clutches, and double check everything. We run it and cycle the motor to make sure the coolant is circulating through the coolers, retorque the primary clutch. I'm sure I forgot something.
With all that said Every dealer has their different ways of doing things.
K
koschak
152
16
18
37
Northern Minnesota
Dealer Prep
When I snowchecked my 2012 Pro I was given 3 options which all had fees associated with them. The first was a "racer setup" (cheapest), and intermediate set up, and a premium setup (most expensive). I believe the racer set up only included a quart of oil added, a gallon of gas, skis put on, and bars bolted on. The rest was to be done by the customer with a supplied check list. Maybe your dealer did something similar to the "racer setup" for you?
Good luck with the sled, you will love it!
mud99
214
107
Truckee, CA
Yeah, it seems like a sweet sled...lots of little changes from the 2012 I have now (which is becoming the wifes sled)
So far I have moved the skis to the narrow spacing, and swapped the 20 sized battery for a 9ah battery which I had on one of my other sleds which is a lot lighter and gives better access to the belt, mounted my GPS, installed tether, moved kill switch down the bars next to the bar clamp, filled up with VES gold, and 5 gallons of additional fuel so it doesn't smoke like a pig.
I'm a little pissed though, I broke the locking tab off the connector for the instrument cluster, so I guess i'll have to hold it together with zip ties and electric tape...
A
aebsledder
1,512
858
Gallatin Valley
Doesn't Polaris provide some type of checklist? I know the Cat dealer here heat cycles them before they are given to the customer. I would think you would pay close attention to clutch alignment, belt deflection, etc? Seems like the factory would have good reason to be sure a certain procedure is followed every time.
snowman80
425
210
ND
Yes we do have a PDI. We don't check alignment but we check and adjust belt deflection.
wang11
207
69
Idaho Falls, Id
My sled showed 88 mph on max speed when I got home!!! I hope it was warmed up wasn't that happy about it
polaris dude
3,500
1,058
Grand Junction, CO
Don't they all show that regardless? Idk why but it seems like most polaris I've seen say that... maybe its saying that is the maximum it should be driven or something?
I would hope they don't have the track spinning that fast im pretty sure its terrible for the paddles
M
mulestar
235
55
Mine had a max of 20mph...for what it's worth.
Ski-Dont89
749
313
WYOMING
When i picked up my pro yesterday...the dealer setup it up full of oil, full of gas, and when i got home and started inspecting i found a set of 10-62 weights in the tool kit. I havent checked for sure yet but im assuming they dropped in a set of 10-60s since we ride at higher elevation. needless to say im happy with my dealer.
