must just be the lighting in your pic, they just appear different!
Thanks for all the great info guys! Here's a couple of pictures..The right footwell gets trimmed pretty agressively. (weight loss)
Can you show us a picture of the other side (speedo bearing side). Thanks
Interesting...Thanks for the detailed pics, I have some more questions on this install as I'm currently working on the same thing and would like to have her back up and running ASAP as the snow is coming. As I understand when you install the Avid case it drops you down a fair bit. I have been told by Robbie @ Avid that the rear suspension has to be moved back and down 1"? I'm only going from a 151' to a 155' as I bought a takeoff 09' Dragon Skid. Is he refering to the front mount holes or the rear mounts or i would suspect both? I can't see why I'd have to move the suspension at all as it should just bolt in but I'll go with his opinion as he is the expert. Can I see a pic of how you re-locateed your suspension to accomodate the case? The more I look into this the more I'm not sure if I'm qualified for this after more than a 6 pack.?? I intend on using the 8 tooth 3" pitch drivers. Should I go with a longer track than the 155" with the 155" skid to get away from having to trim the rails? My skid did not come with any wheels on the skid so I'm open to any setup on the skid to accomodate track length.
So to my understanding I need these Anti Ratchett Drivers but doesn't say anywere that I need to trim my rails to make them fit!! HELP ME PLEASE
Last Question is on gearing, What's everyone doing for gearing with these Cases and Longer Tracks?
I'm sure you'd see a huge improvement "planing out on the snow" by getting the chaincase and even further more by putting in the 8 tooth drivers. The 7 tooths make a nasty sharp radius and make a larger attack angle.. Good Luck! Let me know if there is anything else that you need..
Andy
Yes I ride the steep and deep, I elected to go with the 155' because i got a killer deal on the Dragon takeoff, and it was basically what I was looking for. I didn't realy want to go with the 174' track or the 162' for that matter. 155' will be just perfect as I love to jump my cliffs and play in the trees as well. Basically where I ride its deep pow everywhere all the time and its the best length for my riding style. I am going with the 2.5" Camo Xtreme is the reason for the chaincase mod. What have you decided to go with for gearing?
