Need help with A-arm questions
I am trying to take off my a-arms to get them powder coated. I have a couple of questions. 1. Are the fittings in the A-arms pressed into the aluminum spindle? 2. Is the lower A-arm pressed on to the metal fitting. Or do I just need to hit it harder? I have attached a couple of pictures to show what I am try to take apart.
Any help would be great.
Thanks,
Snowjockeymt
J
Dec 1, 2007
79
6
8
Layton, UT
Once the clip is off the ball joint, you just have to hit it hard enough and it will come out. I didn't use a press to take them out, or put them back in.
R
Dec 26, 2007
45
1
8
when i did mine i just hit the side of the spindal and the balljoint came out of there then i used a airhammer to take it out of the a arm and had to have them pressed back in, i wouldnt use a hammer to put them back in it can reck them, thats if your putting new ones in, if not id press them out too
D
Oct 13, 2008
768
148
The ball joint is tapered and when you tighten it they kind of press themselves in.You do not need a press to get them out but it does make it much easier. I just hit mine repeatedly until they came loose. Aluminum and steel like to stick together.
