Good news guys! We got our sourcing problem resolved and the Spooled-Up kit is live on the website. This is a product that I spent half of last winter developing and am very excited about so I'm happy to have it back live.
We have not added them to the site yet but we have a couple new cost effective add on products to make the installation easier.
OFT cam timing tool, $30. This allows your cam timing to be as simple as get the engine to TDC, align the cams to the tool. Rotate the engine a few times and check again. If it fits, it's good. If it doesn't repeat. No guess work.
OFT CNC cut cam sprocket, this is for the exhaust cam that normally you would have to die grind out the holes to correct the cam timing. At OFT Racing we want to make your install as easy as possible so we have CNC cut cam sprockets so you simply remove your sprocket install our then line up the links using our cam tool. No grinding, no guessing how far to grind, we've done that for you. This is a exchange program to keep your cost down. If you'd like to keep your stock sprocket the cost of a new OEM sprocket is in addition to the $30.
The Powercommander does not operate a external injector. So we utilize the 30 percent larger injectors instead. But it is truly no tuning required as a advantage over your current set up.
