G
So, first ride of the season doing a little hill climb and the engine stutters bad 3/4 of the way up. It then did it the rest of the day at varying throttle positions (WOT, on accel or even constant cruising).
It feels like it's dropping a cylinder for a second then picks back up. Also, it was hard to start intermit (5+ pulls) and on a couple occasions died at idle. It caused a few near stucks and some worry about being on the wrong end of a tow rope.
Our guess is that it’s loosing spark but both ignition coils OHM ok and cost $90 each so I’m reluctant to throw them on.
I did a search and found others had TPS, ECU & voltage issues but nothing about a cylinder type misfire which is what I perceive this to be. Any other ideas or things to check before heading to the parts house? Any one else have a bum coil?
Thanks.
P.S. Stock motor, 2500 miles, exhaust valves cleaned, new gas, plugs replaced, MFD displays normal, no engine lights, does not die when put in reverse (usually).
Thanks.
