Any color you want as long as it's black sure rings nice to me these days.
Bryan
Sent from my SM-G928V using Tapatalk
Haha! Perfect.
What's this semi gloss everyone is mentioning? Is that what the matte black on your site is?
Note: this_feature_currently_may_not_be_available_in_some_browsers
Bryan
Working on matching the LE green now. Unfortunately every manufacturer seems to want to change colors every year to a new color that nobody can match easily unless you have an in with a manufacturer. I don't really want to order a custom batch cause it's expensive to do. Any color you want as long as it's black sure rings nice to me these days.
Bryan
I just talked to brian last night. He said he's got some 'classic' cat green ones but he hasn't matched the limited lighter green yet. Sounds like 2013-2014 snopro green.
I have a set in that color sitting on the shelf.I was actually hoping for the classic green. I like the darker green. The new lighter green is good but I like the older color.
I do it for Front Range Arctic Cat cause they order it in batches. If you want that color I can do it but it I'll have to wait until the powder coater is doing it in a batch.Haha! Perfect.
Haha! Perfect.
I cut about 3" of plastic bottom panel at the
boards off. Opened up the footwells a ton. Can actually get my foot in there now all day long on a deep day. Does not pack snow in there like it used to. More area I can use now. Should have done this when I installed them. Pretty much just cut right before the tube that goes vertical in the front. Started about 3" at bottom of boards and tapered the cut up toward the bolts that hold the toe kick plates on at the vertical part of the tube.
Nothing in the plans right now.Are you going to have a summer sale?
Yes do not try to over tighten them. Just get them to bottom out nice and snug, might be able to tighten 1/8th of a turn once bottomed. I lay down pieces of painters tape to get a perfect straight line down, then use a center punch before drilling or the drill bit can walk on you since the bars are round. I forgot what drill bit size is used. Just call BMfab and ask.
Correct. All tube board manufacturers let the end customer decide how many and where to put traction aidsso they are not pre drilled or pre marked for the screws?
Would you be open to group buy?Nothing in the plans right now.
