--With the weight shown in picture 427lbs, subtract 5lbs = 422lbs for tank yet to be installed then add back in appropriate lbs for coolant and 1 cup of gear oil. Should still come in around 430ish and lighter than the 13 Pro RTR no gas at 438lbs by 8lbs.
--Lighten it up even more for another $1500 with belt drive, HCR cooler(next biggest, cost effective weight loss), and driveshaft. These mods could be worth around 15lbs for a RTR no gas weight of around 415lbs RTR no gas.
--2013 Pro 238lbs RTR(the "holy grail of flickable snowmobile weights") compared to 415lbs PC with +40-50HP = 23lbs less than Pro(and a few more $)
--You could turbo a Pro, add a water/air cooler and gain some weight for the same money, but you still have a weak crankshaft and loose pistons
--After all these mods to the PC, it is a stronger, solid, more powerful, and reliable machine
