G
This is the setup Im going to go with.
I am going to give the Koso a shot
Sent from my iPad using Tapatalk HD
X3 for the Koso for me. Anyone have info on how the boost sensor is installed?
I was never lacking for power last year so I see no reason to fiddle with it.I think i will do the same. Are you changing your pulley's on your S/C?
I can look at mine if you have any specific questions. I had my dealer throw it on when they did the turbo install. It looks pretty straightforward.
On my MPI turbo it looks like it was pretty easy - to get the boost measurement they just spliced into the boost line that goes to the GEMS box using a t-connection. That "boost" line runs up to the little black KOSO box that has the sensor (they mounted that to the black plastic radiator shroud) - the wires then run from that up to the gauge (sits to the left of the stock yamaha gauges).
Make sense?
Could you post a picture?
Looks good thanks. How many lbs of boost you running? how do you like the kit?
