G
After the first trip to BC we are down 3 belts between two sleds (Cords hanging out, not totally blown). Only about 120 miles total over 3 days.
Getting the same BS response form dealer about not properly breaking the belts in, even though the first belt I lost was washed, scuffed and had a 18 mile break in. There was no heavy continuous riding that would have even got the clutches hot.
The alinement has been checked again and is correct according to cat, and I checked the secondary for the jack shaft play, its fine. I found a solid black ring of rubber about 3/4" wide at the bottom of the primary at the end of the last day. This and the fact that the defection changed a lot very quickly leads me to think that the side clearance on the primary is not set properly.
We were also experiencing a lot of belt chatter as we were riding tight trees and where in and out of the throttle all the time. Could this also be a result of improper clearances.
Is anyone else experiencing this. I would really like to get this sorted out before the spool goes on so any help would be great.
