over heating on my RMK
TOlsen
206
13
18
Martin City, MT
In addition to scratchers I extended my flap a couple inches. I used light weight plastic(stair tread from hardware store $4) so it didn't weigh down the flap. Catches quite a bit more snow coming off the track, helped lower my temps signifgantly in marginal trail conditions.
guidoxpress
5,105
1,506
Wasilla, AK from MT
is your radiator removed..if not..REMOVE IT..
scratchers, you may have a faulty thermostat...or air in your coolant system and need to bleed it out
if you are overheating within a block i dont think scratchers or the flap are going to help you, its gotta be low on coolant. jack the front end up about a foot, pull the bleeder screw from the head and add coolant untill it comes out the hole. i had the same problem on mine last year. it showed i had coolant in the tank, but when i bled it i added about 3 quarts more coolant.
