Fly Racing F2 Carbon Dubstep Helmet signed by Tucker Hibbert
CROW
1,479
211
Michigan
Size Large
Brand new, never used
$400 plus shipping.
SNELL M2010, DOT Approved For USA - other standards include: ECE and AS (Australian). Meets or exceeds the toughest safety standards on the market
Composite Construction Shell – outer shell is constructed using state-of-the-art, aircraft grade woven carbon fiber and Kevlar® composite materials, which creates superior strength while remaining extremely light
Dual Density EPS Liner – two layers of EPS (Expanded Polystyrene), one softer one slightly harder, combine to provide more progressive impact absorption for different levels of impact
Multi-Port Air Induction Cooling System – eleven (11) intake and four (4) exhaust vents create massive airflow to keep your head cool
Tri-vent Goggle Anti-Fog Vents – three (3) air intake vents above goggle eye port draw air from goggle to help clear away fog
Flow Through EPS And Comfort Liner Air System - EPS (Expanded Polystyrene) and comfort liner align to maximize airflow
Quick Release Washable Comfort Liner and Cheek Pads – plush liner absorbs sweat, provides plenty of ventilation, and is easy to remove and clean with out quick-snap system
Custom Molded Rubber Trim With Nose Guard - with its smooth lines the integrated nose guard helps keep pesky rocks away from your nose
Lightweight Aluminum Hardware – helmet is constructed using super-strong, lightweight machined aluminum screws, rivets, and D-rings for superior strength and years of worry free use
Optional Carbon Fiber Intake Vent Wing – can be added to the helmet for increased direction of airflow on the front vents
