E
I just got done building a KX450 snowbike with reverse using the ATV bottom end. I couldn't run the stock kx cdi because the atv had a dc style 3 phase stator so I put on a programmable one and had to build the curve myself. Right now It likes max advance around 53 degrees! I can only guess because it still has the atv 12:1 piston and I'm running at high altitude. I'm going to rebuild it with high comp piston over the summer and see if I can get a faster more efficient burn so I don't need so much timing.
I know most of the tuners only give + and - degrees and you can't see the real curve or total advance. Does anyone have any actual curves? It would be interesting to see what works on snow bikes under hard loads compared to a dirt application.
