H
Anyone have a picture or description of how the clutch alignment tool is supposed to be used.
Note: this_feature_currently_may_not_be_available_in_some_browsers
lay the other end down in between the sheaves on the shaft of the primary. Looking at the clearance between the tool and INNER sheave should be not more than 1.5mm.
Its touching the outer sheave on the secondary, but the primary was my concern as it doesn't touch the bottom.
Yes the tool is too wide, it is an 09 M8 with CPC adjustables.
The tool is AC part number 0644-427 (1.65" offset)
I believe that tool may only be for the 10" secondary..??
http://www.alpha-sports.com/tools/arctic_sled_tools.htm
went out and checked on it using the method jim suggested and it looks as if it is spot on without any shims, dumb luck I guess.
I'm going to adjust the secondary using the BDX adjuster and then re-check the alignment.
Thanks all
Hyperduc - do you know how to adjust your belt deflection? Are you saying you have a BDX deflection adjuster installed? There is no secondary adjustment used in checking the clutch alignment. Just make sure the sheaves are closed as far as they will go, and you have the secondary all the way in on the spline. I have an AMP deflection adjuster and I put a small amount of tension on the allen bolt that goes through the adjuster to hold the secondary in place. Then I use the alignment tool to check. hope this helps.....
