R
Well...it really says alot that you dont know where you said polaris 800 was 150 hp stock...why dont you look at your website...i was interested in buying some of your stuff...until i realized you show no dyno charts or even hp numbers with yout polaris big bore kit...only said it is cheap...which indeed it seems
Since your website is made for 2 stroke heads...you should know an offset combustion chamber to the intake side evens out the heat inside the cylinder and the intake charge is cooler because its away from the exhaust side
Now where did i say i havnt seen this engine? I said i didnt really look and measure specs of this motor before
Now are you looking for piston dimensions or clearence between the cylinder wall? These are different things here...
We all love Alter Egos... Should we guess who you are?? I have a pretty good idea.. but you keep on with the facad.. it will be good fun
Offset combustion chamber on a loop scavenged engine.. LOL... Better go back and study your books some more... Intake charge away from the exhaust with an offset chamber.. WOW!!!
The chamber is not in play when you are "intaking" ... the piston is at BDC....
So, how do you keep the intake charge away from the exhaust??.. you splitting the cylinder?? LOL
This just keeps getting better and better.. Maybe you have one of those offset cranks also???:face-icon-small-con
Too agressive exhaust valve?? LOL.. that is a good one!! So I guess you can get more "fully open" than " fully open" Is that what you mean?? So when you are past fully open, then you are too agressive... right?? good to know.
[Porting, I have no idea of what the ports inside this motor look like,
Aah.. above is where you state you have not seen inside this engine!!
anyway, you keep up with the total BS-ing of people.. maybe discredit AAEN and myself some more..... that seems to be working for ya...
Seems Bikeman sure gets mentioned in most of your posts... hmmmm
WOW!!!
