I
Possibly a ltd build of speedwerx sc'd sleds to be offered.
They already sell a boosted 4 stroke with over 200 hp. Why not a 2 stroke?
Because every idiot that shouldn't own one will and it would be disastrous for warranty claims.
Could you imagine how many times a season a sled would be in the shop for warranty work with a 2 stroke turbo? They are FAR from pull and go, very far... They would have to come with 0 warranty and you would have to set them up and tune them yourself, no way a manufacturer could set them up for every riding area and conditions.
While I agree with you on this, every turbo manufacturer will swear up and down that their system is pull and go. That is all I hear from them when they are trying to sell a system.
Silber setup on the Axys is as close as pull and go as you can get. The key is hacking the ecu. Piggyback systems are problematic at best. When the perameters can be changed across the whole ecu, then it works pretty good. The factory engineers could do this if they wanted to. Just not sure it is a priority.
Why is it so hard to unlock the cat ecu and change the factory settings?
Is cat doing something to prevent this from happening???
A super charger and the factory ecu tuned to fuel it might be a good fit???
