M1100 with Team secondary
M
Feb 6, 2012
8
1
3
Hey there guys, quick questions for anyone running m1100 with Team secondary, are you running a shim on jackshaft between secondary and bearing; or just running the secondary directly on the jackshaft with no shim.
Thanks for help in advance.
0neoldfart
968
574
93
Thorsby, Alberta
Get an alignment bar
I have a Tied on two M's - one needed a shim, the other needed two for correct offset. I would suggest you get an alignment bar to determine if it is required.
M
Feb 6, 2012
8
1
3
Okay, figured i would need to. Do you know what offset of alignment bar and what spec i should try to get in in between?
Thanks, Matt.
