Cleaning exhaust valves 2009 summit 800
D
Jul 30, 2008
2
I have a 2009 summit xp with a little over 3000 miles on it and have had no engine problems, so I thought it might be time to clean the exhaust valves. Does anybody know the proper procedure for removing and cleaning them? I have been using Amzoil Interceptor oil. Thanks............
milehighassassin
Moderator: Premium Member
7,464
2,060
FOCO/VAIL
It is pretty straight up on all sleds, remove un-bolt take not to the direction they go in. Some sleds will only accept one way, other you can put them in upside down. You can get away with re-using your gaskets but it depends on how careful you are in taking them off. With 3k I would buy a gasket kit just in case, probably due.
Visi
189
Paradise, CA
No problem. It took me a half a season to figure that one out. All power on top end but bottom end sucked. Started around 2400 miles.
