Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 11-29-2015, 09:48 PM
chad006 chad006 is offline
Currently: Not set.
chad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond repute
Default Turbo etec IAT's
Hey guys, I'm runnin a non intercooled aero on my xm. Just curious if anybody has installed a guage and tested non intercooled vs intercooled charge temps? I'm tryin to decide if I wanna build a water to air setup for myself or go to snow to air. And I'm just curious as to what kinda charge temps you guys are seein.
Thanks!
  #2
Old 12-12-2015, 04:11 PM
kfa670 kfa670 is offline
Currently: Not set.
kfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond reputekfa670 has a reputation beyond repute
Garage
Default
I just installed a sensor in mine over the summer, mainly out of curiosity and I had an extra. It is plumbed into Aeros snow/air cooler.
I have only had one ride with it and didn't pay mutch attention yet but going up the trail in and out of the boost (9lbs) I seem to remember it was reading 98 degrees.
More testing needed I will let you know in a few weeks as our snow isn't very good yet
  #3
Old 06-02-2017, 09:12 AM
Currently: Not set.
Garage
Default
Just following up a little on IAT's with the Aero. I have an incredibly vented sled. Its practically swiss cheese with Aero in the normal location.
Running 9-10 lbs over the last couple winters with the Air/Snow Airbox, I would see a max intake temp of about 170F on long pulls. It would cool back off to the low 100s on the trail. I would also see quite a bit of RPM fade as the heat built up.
Recently this spring I installed a fresh air intake using a 4" to 3" elbow reducer off the turbo and then just some high temp silicon tubing routed up to a hole by the dash with a unipod and prefilter (thanks nuttyn01) I cut windows in the unipod so it would let lots of air in but still have its shape and flexibility.
The result was incredible.
IAT's dropped 65 degrees. I have been seeing 108F max on the same big pulls and thats in 50 degree weather. RPMs consistently held where they were supposed to. No noticeable bottom end difference. I had to drop two clicks running the same boost. My guess is there were a few HPs hiding in that 65 degrees...
IMO... I should have done this years ago
The Following 2 Users Say Thank You to kfa670 For This Useful Post:
fredw (10-17-2017), madmax (06-21-2017)
  #4
Old 06-21-2017, 10:24 PM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
That is pretty impressive intake temp drop.
  #5
Old 06-28-2017, 11:43 PM
Currently: Not set.
Garage
Default
Max,
I have to say it was one of, if not the best mod I ever did to my beat up old turbo sled
  #6
Old 10-12-2017, 03:02 PM
Bendy Bendy is offline
Currently: Dooin the Snowdance
Bendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond repute
Default Cold air is a must!
Its no surprise your intake air temps dropped 65 degrees. My first turbo 2S wouldn't even run without gurgling and spitting without a fresh air intake! Night and day. Just ask any turbo builder.
  #7
Old 10-18-2017, 12:00 AM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
Put a intake air temp gauge on my aero, a few years back and I also run a cold air intake.. Even on long runs its real hard now to get much over 100f, made a big difference grabbing cold air, run boast to 8 lbs most of time
The Following User Says Thank You to fredw For This Useful Post:
kfa670 (10-23-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2013-14 Silber Turbo ETEC XM Turbo Kit Thread Starter — Silber Forum — Ski-Doo: TURBO Replies — 7 Last Post — 12-31-2013 05:53 PM
Thread — Diagnosing ECU code 5 IAT sensor Thread Starter — mutti_wilson Forum — Arctic Cat: M Series Replies — 7 Last Post — 01-09-2012 11:32 PM
Thread — Need RESISTOR values: Servo, IAT, Exhaust, Headlight Thread Starter — fixit Forum — Arctic Cat: M Series Replies — 1 Last Post — 05-03-2011 09:29 AM
Thread — Possible iat issue BDpro Thread Starter — allblowdup Forum — Polaris: TURBO Replies — 8 Last Post — 02-13-2011 12:30 PM
Thread — IAT or MAF location on 07 Phazer Thread Starter — Hambone24 Forum — Phazers! Replies — 1 Last Post — 02-07-2009 08:44 PM
