Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 02-13-2014, 09:26 PM
redbarchetta redbarchetta is offline
Currently: Not set.
redbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud ofredbarchetta has much to be proud of
Default crankcase vaccum for fuel pump
I have a 98 mxz 670 and am not getting fuel to carbs, I took the fuel pump out and manually put vaccum on the pump and it will pump fuel. Can anybody tell me what the vaccum should be out of crankcase and why it may be low I have 110lbs of compression!! All help would greatly be appreciated thanks!!!
Rate this post: Yes | No
  #2
Old 02-13-2014, 09:28 PM
Currently: Not set.
Default
Forgot to mention that I have plenty of fuel coming out of the tank line to the pump!!
  #3
Old 02-13-2014, 09:30 PM
byeatts byeatts is offline
Currently: Not set.
byeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond repute
Default
Quote:
Diaphragm can become wore /weak
  #4
Old 02-13-2014, 09:55 PM
nuttyn01 nuttyn01 is offline
Currently: Not set.
nuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond repute
Default
Make sure the signal/pulse line to the pump is sealed and does not have a crack in it. Maybe a crank seal is out too.
  #5
Old 02-13-2014, 10:06 PM
scratley's Avatar
scratley scratley is offline
Currently: Wearing the wheels of my ktm
scratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond reputescratley has a reputation beyond repute
Default
Quote:
x 2 very common problem with them.. Happened to mine and my buds back in the day
  #6
Old 02-13-2014, 10:09 PM
Currently: Not set.
Default
Quote:
Are you talking about the line that runs from crankcase to pump? If so that is in good shape!! I was thinking crankcase seal as well but no way to check with machine not running!!! I could check it with carb cleaner if it was running right?
  #7
Old 02-13-2014, 10:11 PM
Currently: Not set.
Default
Quote:
Can you buy a new diaphram or rebuild kit or need whole new pump?
  #8
Old 02-13-2014, 10:16 PM
scratley's Avatar
Default
Parts section says pump is unavailable.. I would check with dealer see what he can find for you...
  #9
Old 02-14-2014, 08:53 AM
tukernater tukernater is offline
Currently: Waiting on more snow
tukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond repute
Default
Just cover each carb, pull over a few time and if one cards got no suction or very low suction that's the side the seal will be shot.
The Following User Says Thank You to tukernater For This Useful Post:
redbarchetta (02-14-2014)
  #10
Old 01-08-2017, 09:17 PM
Slicnic77 Slicnic77 is offline
Currently: Not set.
Basic Member
Slicnic77 is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Where can I get a fuel pump and could a weak fuel pump be affecting performance alot Thread Starter — cumminshp Forum — Arctic Cat: M Series Replies — 15 Last Post — 11-29-2012 03:01 PM
Thread — Raw Fuel in Crankcase Thread Starter — Mazam Powder Forum — Polaris: GEN 2 Replies — 2 Last Post — 12-05-2011 10:01 AM
Thread — Fuel tank + Fuel Pump + Fuel Filter for 2006 900 RMK Thread Starter — Dogmeat Forum — Chassis/Tunnel (Swapmeet) Replies — 0 Last Post — 12-06-2010 07:48 PM
Thread — What size vaccum lines do you use? Thread Starter — guidoxpress Forum — Polaris: TURBO Replies — 4 Last Post — 09-30-2010 01:16 PM
Thread — M7 fuel in crankcase? Thread Starter — Zoob66 Forum — Arctic Cat Replies — 0 Last Post — 01-04-2009 08:00 PM
no new posts
