Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 12-13-2010, 04:05 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default 09 800rmk wont rev, acts like a rev limiter at around 7000 rpm
Im posting this for my roomate. His sled is an 09 800 dragon with around 1500 miles on it. Rode it all last year, and had updates done to it, has run solid all the time, other then adjusting the idle up a hair last year, its been 100% rock solid. We took it out to cooke and rode it before t-day, rode ALL day in over the hood snow, worked great, never missed a beat. He took it home and went for another ride and now the thing is acting all crazy.
symptoms.
-if you creep the throttle up, it hits around 6500-7000 and just stops reving, acts like a rev limiter, then the check engine light comes on constantly blinking.
-if you go WOT from idle, it spikes up to just under 8k then dies down to 7k and sounds like its miss/rev limiter. the check engine light stays solid until it idles down.
-it also started idling like crap and barely will run without hitting the gas, idles so low the gauges start to flicker on and off.
I have read a lot on the whole VR failre, etc. but just curious before chasing the thing in circles. He built a tps tester and set it all.. so thats set properly.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
Rate this post: Yes | No
  #2
Old 12-13-2010, 04:46 PM
crashnbash crashnbash is offline
Currently: Not set.
Basic Member
crashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond reputecrashnbash has a reputation beyond repute
Default
Is there a pattern to the flashes, like fives flashes then a short break?
  #3
Old 12-13-2010, 09:44 PM
Default
nope constant single flashes.
__________________
  #4
Old 12-13-2010, 10:11 PM
rmkboxer's Avatar
rmkboxer rmkboxer is online now
Currently: magic mikes backcountry fan cooled adventures
rmkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond reputermkboxer has a reputation beyond repute
Default
there is a sensor problem you need to know the codes
  #5
Old 12-13-2010, 10:28 PM
Currently: Not set.
Basic Member
Default
Single flash is a tps problem. A steady light could be chassis relay, chassis voltage high or low, ignition voltage curcuit, vdc sensor supply voltage low, or intermitant cps signal.
  #6
Old 12-13-2010, 10:30 PM
BIGMEATS BIGMEATS is offline
Currently: 2014 PRO
BIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond reputeBIGMEATS has a reputation beyond repute
Default
Try loosen the throttle cable at the handle bars on the throttle cable tension adjuster up by the handle bar pad. Same thing happened to my 09 dragon loosened up the cable and all was well after that. Might not help but easy check to make.
  #7
Old 12-13-2010, 11:23 PM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
Default
Need to count the flashes to diagnois what trouble code the ECM is seeing.
  #8
Old 12-14-2010, 08:14 AM
Default
there doesnt seem to be any amount of flashes, just constant blinking.. I will check later today and see if there is some pattern to it, I know how patterened blinking goes.. and it doesnt seem to be doing it... but I guess there can be a lot of them in a row, so I will double check.
__________________
  #9
Old 12-15-2010, 02:16 PM
instigator instigator is offline
Currently: Not set.
Basic Member
instigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond reputeinstigator has a reputation beyond repute
Default 800
My money is on the exhaust temp probe being shot! Went through 3 of these last year - They're not cheap!
  #10
Old 12-19-2010, 03:38 PM
ragincajun's Avatar
ragincajun ragincajun is offline
Currently: has a boost boner
ragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond reputeragincajun has a reputation beyond repute
Garage
  #11
Old 12-19-2010, 04:01 PM
95RXL 95RXL is offline
Currently: Not set.
Basic Member
95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute95RXL has a reputation beyond repute
Click Here to Register
  #12
Old 12-19-2010, 05:17 PM
ragincajun's Avatar
Garage
  #13
Old 12-26-2010, 10:41 PM
R44guy's Avatar
R44guy R44guy is offline
Currently: Waiting for Snow!
R44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond reputeR44guy has a reputation beyond repute
  #14
Old 12-27-2010, 12:46 PM
Super Dave3's Avatar
Super Dave3 Super Dave3 is offline
Currently: Not set.
Super Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond repute
  #15
Old 12-27-2010, 03:39 PM
fraufarm's Avatar
fraufarm fraufarm is offline
Currently: wants a money tree
fraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond reputefraufarm has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M1000 High rpm studder, like a rev limiter???? Thread Starter — WyoBoy1000 Forum — Arctic Cat: M Series Replies — 23 Last Post — 03-03-2010 10:04 AM
Thread — Rev limiter? reset max rpm?? Thread Starter — fasta76 Forum — Arctic Cat: M Series Replies — 9 Last Post — 02-16-2010 08:10 AM
Thread — Sled wont Rev past 3000 rpm. Help please! Thread Starter — madam328 Forum — Arctic Cat: M Series Replies — 8 Last Post — 12-07-2009 11:35 PM
Thread — 08 m8 wont rev over 4000 rpm just bogs down Thread Starter — nelad_12345 Forum — Arctic Cat Replies — 5 Last Post — 12-24-2007 10:55 PM
no new posts
