Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 04-09-2019, 10:35 PM
AkRider217 AkRider217 is offline
Currently: Already waiting for winter again...
Basic Member
AkRider217 is an unknown quantity at this point
Default How to tell if oiler has been previously adjusted?
Just bought a used 2013 Pro RMK 800, how can I tell if my oil pump has been adjusted by a previous owner?
Rate this post: Yes | No
  #2
Old 05-17-2019, 07:00 AM
bowhunter11199 bowhunter11199 is offline
Currently: Not set.
Basic Member
bowhunter11199 is an unknown quantity at this point
Default
Interested in this as well
  #3
Old 05-17-2019, 07:48 AM
Big10inch Big10inch is offline
Currently: Still Riding...
Basic Member
Big10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond repute
Default
Ride it and track oil consumption, determine ratio, compare, adjust if necessary.
  #4
Old 05-17-2019, 08:10 AM
dttrusko's Avatar
dttrusko dttrusko is online now
Currently: Not set.
dttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond reputedttrusko has a reputation beyond repute
Default
Inspection mirror and a flashlight go between the clutches.
Look at the oil pump lever arm. There is a scribe on the case and a notch on the lever arm. At idle, the factory position is set so the scribe lines up with the case. If it is a bit rich, the notch will be above the scribe.
To richen it up, undo jam not on top of the lever arm and adjust the screw with an allen wrench to lift the arm up.
__________________
1979 TX 440
1972 Colt 250
1984 Honda ATC 200S
1984 Ford Escort L Wagon, 1.6l
The Following User Says Thank You to dttrusko For This Useful Post:
AkRider217 (05-22-2019)
  #5
Old 05-18-2019, 06:40 AM
Flying Dutchman Flying Dutchman is offline
Currently: Not set.
Flying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond repute
Default
^^ like this^^.........the notch and scribe mark should line up for stock setting. .. the pump is in a tight spot, so removing the exhaust can will give you a perfect view. Don't have a pic, but if you move the throttle lever, the oil pump arm will move, and you'll see exactly what the notch and scribe mark means.
The Following User Says Thank You to Flying Dutchman For This Useful Post:
  #6
Old 05-22-2019, 02:40 AM
Basic Member
Default
Thanks! Although if anybody has any pictures it would be super helpful.
  #7
Old 05-22-2019, 07:34 AM
Reg2view Reg2view is online now
Currently: Not set.
Reg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond repute
Default
Do a search in the pro-ride section - there are pictures of the stock and turned-up oiler setting and the service manual, and detailed instructions on exactly how to do it. Threads are 2012, 13, 14ish.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Adjusted TPS, question. Thread Starter — ottawaair Forum — Polaris: Pro-Ride Replies — 12 Last Post — 09-10-2014 04:21 PM
Thread — How should suspension be adjusted for powder Thread Starter — SpencerA Forum — Polaris: GEN 1 and older Replies — 5 Last Post — 01-24-2012 01:10 PM
Thread — TPS Adjusted and will not start! HELP! Thread Starter — WStilson Forum — Polaris: IQ Replies — 16 Last Post — 01-07-2011 11:14 PM
Thread — Oil pumps. Who has adjusted? Thread Starter — xc6rider Forum — Polaris: IQ Replies — 20 Last Post — 12-16-2010 10:23 PM
Thread — 1M stator problems,previously was a hiccup........ Thread Starter — Goin For Snow Forum — General Snowmobiling Replies — 2 Last Post — 01-17-2009 09:45 PM
no new posts
