C
Just started on my new build. I will be using a 2012 pro Rmk that I picked up for cheap and installing a 1050 wc via a par motor plate and crank shop pipes.
I am new to the wc motors and I had a few questions about the crank shaft. So far I have two 700 cranks and a wc case at our local crank shop up here in Alaska. My question about the cranks is timing, I understand that the crank needs to be timed at 120 degrees but what is the firing order? Assuming I should fire mag-center-pto? And on that note in what retrospect dose the timing key slot need to be with the rod? I will be running an spx ultra ignition so wouldn't it just make since to just copy the ultra crank?
Thanks Cole.
Thanks Cole.
