2014 Arctic Cat M8000 Sno Pro Green 162
BD-Xtreme
267
Brand new only $9500!
Can be shipped or picked up.
Phone 507-263-2244
http://www.bd-xtreme.com/2014m8000snoprogreenbrandnew.aspx
Engine
Type 2-stroke
Displacement 794cc
Cooling Liquid
Cylinders 2
Bore x Stroke 85 x 70 mm
Lubrication Oil injection
Ignition 3D with throttle position sensor
Carburetion 46 mm dual throttle body batteryless EFI
Exhaust APV with tuned pipe, pipe sensor and stainless steel muffler
Fuel Capacity 11.5 gal.
Front Travel 9 in.
Powertrain
Drive Clutch Arctic 6 post (rpm sensing)
Driven Clutch 10.75" dia. Arctic (roller cam)
Drive System Arctic Drive System
Brakes Radial master cylinder hydraulic brake / disc on driveshaft
Suspension
Front Suspension Arctic Race Suspension with FOX FLOAT 3 shocks
Rear Suspension M Rear Suspension with tri-hub rear axle system, Arctic Cat (IFP) shock on front arm, FOX FLOAT 2 shock on rear arm
Rear Travel 16.5 in.
Dimensions
Overall Length 130 in.
Overall Width 44 in.
Ski Stance 38-39 adjustable
Ski Type Mountain 6 in.
Runner Type Single skag w/carbide
Track Type Power Claw
Track Width 15 in.
Track Length 162 in.
Lug 2.60 in.
Pitch 3.00 in.
Standard Features
Push-button engine reverse, dual halogen headlight (2-bulb), front bumper, deluxe digital/analog gauge, electric gas gauge, low oil light, coolant overheat light, high/low hand & thumb warmers, belt holder, altimeter, accessory outlet, low-height windshield, air pump, telescoping mountain handlebar, front-mounted heat exchanger, ice scratchers, drilled lightweight disk brake
