The laser guns are great... and they have become very affordable... but the temp tape , IMO, would be a better "max" temp indicator for testing purposes.
Note: this_feature_currently_may_not_be_available_in_some_browsers
What does the fan draw for amps. Not a lot to spare when you have a turbo.
It draws 1 amp. You can either plug it into the dc power port or use a rectifier ( we have them availiable ) and you can plug it into the ac side.
Cool idea, but would your left leg not be soaking wet from fan blowing hot air at your knee
TEMP READINGS
that tube looks close to the belt. has anyone hit the dash hard and pushed it into the belt? looks good other than that!
If anyone is looking for one in the edmonton area we have them in stock.
Thanks Chris 780-963-0080 Parkland Motorsports
That DC POWER plug is NOT fused and DOES draw from the same regulator that feeds the ECU... so, in fact, you ARE plugging into the ECU power following the MTNTK directions.19) Route wire to the DC POWER plug located on the left hand shock tower.
DO NOT PLUG INTO ECU POWER
