Display not lighting up
Big D rmk700
1,084
167
New Ulm, Mn
So Sunday after riding a good amount of powder my sled and a buddy's 2016 Axys displays didnt light up for a few minutes mine did same thing yestersday in the morning ran great all day. Anyone else experience this and if so is there something serious that could be going wrong.
Thanks Darren
N
Aug 27, 2012
165
Bend, OR
Was it when started cold? Was the idle pretty low? With a low idle the displays won't light up and the headlights will flicker/not work. Usually clears up if you blip the throttle or bring the R's up.
Ian
N
Aug 27, 2012
165
Bend, OR
Are they snowchecks with the pidd display? I'm not sure if its just the snowchecks, but the display is powered by one of the two relays near the egt sensor I believe. Might be having an issue with that freezing up if in cold weather and moisture has gotten inside.
Ian
dragonflats
433
92
st. james mn
Yes still doing it start it up no display until engine warms up then display works fine
Sent from my SM-G955U using Tapatalk
