E
Evolution Powersports is proud to announce that we have completed the fabrication and electronics for the first of a whole line of No Compromise Yamaha VIPER / ARCTIC CAT 7000 Turbo kits. This turbo system is called the BIG CHUTE VIPER.
The heart of any great turbo system is the turbo and fuel/boost management system. Our turbocharger is a TiAL/EVOPS Billet Wheel IHI Turbo which is capable of 400+ hp. These are the same turbos that are dominating the Arctic Cat 4 Stroke mountain and drag race markets throughout the US and Canada. This turbo, despite its high maximum power potential, lights up instantly. Our electronic package consists of an EVOPS spec altitude compensated boost/fuel controller that is light years ahead of the currently available options on the market. Our controller allows us to scale up the fuel injectors to allow more fuel without affecting the off boost fuel mapping. We also re curve the stock timing map to make it more boost friendly and lowering octane requirements. The timing re curve also removes the need to install a head shim at this power level.
The kit also features:
• WATER TO AIR INTERCOOLING with BILLET machined heat exchanger
• LARGER FUEL PUMP
• COLD AIR INTAKE WITH REED VALVE BYPASS
• STAINLESS STEEL EXHAUST
• SIMPLE INSTALL
• 550 CC DROP IN REPLACEMENT INJECTORS
• NO TUNING REQUIRED
• CUSTOM SILICONE INTAKE, CHARGE TUBES AND WATER LINES
More details will be released in the coming days and weeks.
• LARGER FUEL PUMP
• SIMPLE INSTALL
