making a 1m into a front dump
D
Dec 3, 2007
242
4
18
52
grande prairie, alberta
i recently started having problems with the typical bog when carveing to the right. i don't know what all the solutions are but i have seen posts where guys have turned their exsisting can into a front dump. anyone have some tips for me, i was thinking of cutting the tailsection of the pipe and turning it 90 degrees to face forward and have the can horizontal instead of vertical. is there a better way?
P
ProKlim
400
13
18
North Dakota
Right by the outlet of your pipe there is a weld, cut the weld and turn it to where your can sits where you want it, then reweld where you cut and your done. Also, depending on the outlet of your can, you might have to cut it and make some sort of turndown on the end, then go to the arctic cat store and pickup an 06 deflector for around $20 and your set. Did not hurt performance and cured my bog. Cheap fix. Here are a couple pics.
Hope this helps.
Trent
BTW, I have this pipe and can for sale if your interested in a speedwerx and thing setup.
K
Dec 4, 2007
264
150
CNY
Cat makes a kit to update your sled to front exhaust. The kit retails for $133.95
FRONT EXHAUST KIT
Includes front exit resonator, heat shield and outlet deflector.
For 800 & 900 carb and EFI models.
Application_________________p/n
'04 MC 800, 900; '04-'05 KC _4639-235
'01-'03 MC 800; '03 MC 900 _4639-251
