Pro RMK spindle on an Axys
flying frenchman
553
186
Alberta, Canada
So trying to kill the attack angle, so the only way to do it is to drop the front end down.
Would the pro rmk spindles work ? Has anyone tried this yet ?
I don't care how easy the Axys flops from side to side , my pro handle like a charm. Kinda like it better.
chralle
57
10
8
33
north of sweden
I'm also running the proride spindles on my axys
Couldn't tell the difference in handling but I know for sure that the proride spindles are tougher than the axys ones.
Skickat från min GT-I9295 via Tapatalk
Teth-Air
4,561
2,790
Calgary AB/Nelson BC
www.specified.ca
Yes, the shorter spindles work well on the AXYS. I did however run our offset spindles to narrow up the ski stance and also sucked up the limiter strap 1". This was a great combo to reduce trenching and reduce transfer. Now with our suspension coupler I have been able to go back to stock setup and still be in control. It still does trench a bit more with the stock set up though. I think the 8 tooth drivers would be the best answer.
goridedoo
3,868
3,544
8 tooth drivers if you have the 2.6?
xmk1080
451
144
I'm running the pro spindles, 8 tooth drivers with the 2.6 track and zbroz 36 inch front end set at 35 inches along with raptor shocks and absolutely love it! I'm actually going to try the pro offset spindles next, it's a blast to ride in the trees, drainages, sidehilling, it just does everything better! I'm also geared down to an overall 2.42 gear ratio since I installed the 8 tooth drivers and tki belt drive.
Scott
Scott Stiegler
69,618
11,737
W Mont
I have my 2013 Pro RMK spindles sitting on the shelf if anyone is interested.
flying frenchman
553
186
Alberta, Canada
Just test driving one for the weekend. The first thing I notice is this sled sits way too high and has a steep attack angle. With a low attack angle on my pro it just floats. My skid is also pulled back 4" on my pro. So avoided the drop and roll. Sled is very controlling and fun.
Ordered myself a new 163x 3" but thinking I will set it up like my pro if possible . I will swap my spare driveshaft and drivers and my 2.5 CE and run it like this most of the time. With this motor it will haul ***. Will figure it out for the 3" as time goes.
A
ak
2,776
723
I run the pro spindles and 8 tooth drivers on my axys, it helps with handling but I still feel my pro rmk handles better. Would like to try a narrower ski stance on the axys.
goridedoo
3,868
3,544
Could you elaborate on "better"?
A
ak
2,776
723
The pro just seems more easier to ride and gets on the snow better than the Axys both sleds having a 2.6 track.
With the taller spindles I noticed more feedback through the bars.
I'm wanting to try the offset pro spindles on the axys next.
Main reason for the spindle and the 8 tooth driver was to get a better attack angle.
Teth-Air
4,561
2,790
www.specified.ca
I completely agree that the AXYS has way more feedback with the taller spindles. Seems to have more leverage effecting them when on a side hill so when you catch something it is more pronounced.
Norway
1,978
476
83
49
Ok, that does it! I'm getting ZRP narrow spindels for pro rmk to put on my Axys. My pro was a blast with those and narrow bars.
Sent fra min S60 via Tapatalk
diamonddave
Chilly’s Mentor
5,577
3,890
Wokeville, WA.
Do you have any pics of this? Very curious to see...
flying frenchman
553
186
Alberta, Canada
Been using this kick *** set up for 5 years
Paint ain't pretty, it's been 5 years.
