I can't tell by the pictures but how did you mount that. If you would post more pictures that would be great!
He used the link brackets as clamps on the edge of the bag. Definitely may be trying this!
I have the same bag mounted to my G4 and I think it's the best bag out there. I made some aluminium brackets to mount mine using the lock and ride latches and they've worked well so far. I'll take a pic and post it later. I did break one of the sides of the T-slot bar when I cammed the first one over because I left two washers on it and a 1/8" bracket is too thick for that. Overall though, once I removed the extra washer on each it made the setup really solid still and no breaking those expensive latch parts. I like how easily I can take the bag off also. My new sled will be getting the same treatment once it arrives.
Here you go. I used the Linq mount holes so the brackets have to be elongated a little to accomplish that. I decided on stainless carriage bolts to mount the brackets and nylock nuts underneath. I put a 5/32" rubber pad between the mounts and tunnel not only to keep it from wearing the powder coat but it makes a clearance for the T-slot heads. Neoprene washers would prob be just as good.
Dude, ill buy a set of those brackets with rubber if you make me a set. I was thinking of a way to mount that bag.
