K
Hello guys.
First of all I have a 2006 Yamaha turbo'd apex boondocker turbo, Last year it blew the top lager diameter oil hose on the oil tank(cracked near tank and sprayed oil out. It threw a code low oil pressure. I shut it off towed it back. Let it sit in the trailer since.
This week I fixed the hose, purged the oil system, it still had the low oil pressure code flashing it would not start.
So I took it into the dealer, the verified the oil system had been purged properly, Cleared the code, They told me that it started and is running now, But that it was popping out of number one cylinder (clutch side) They did a leak test on all the cylinders, and number one would not hold at all, the other three pretty good.
I picked it up from the dealer and took the head off today valves look to be in pretty good shape, all cylinders look good, pistons looks good. I put alcohol in the intake ports in the number one cylinder and did not see any visible leaks, as well as the exhaust side on number one cylinder. Any idea's? Piston piston rings? I can turn the motor over by hand good, everything looks good to me, Any idea?????????? Thanks
