Where can I get a manual chain tensioner? I've read many accounts of chaincase auto-tenaioners breaking and taking out gears. Is this a fluke? Thanks for any input/opinions.
I just ordered mine from supreme tool. 85 bucks plus shipping. Hoping for the best.
To bad the adjuster didnt go in the cover. Not saying it wont work, just looking for some pictures of the install.
Is it worth doing this? Does cat replace chaincases if they explode?
Having the adjuster on the cover is a pain in the a$$. My last sled was a Nytro and the adjustment bolt was in the cover. Could never see how tight the chain was or wasn't, had to use yamaha spec. Broke Two chains because of improper tension.
Thats not much good either. Really hoping the dealer can just set the chain to spec with the new manual tensioner and be done with it. Pull cover off midseason to check tension. Thats the way it should be. Whether that is the case ill have to wait and see. Fingers crossed.
Yes Arctic cat has been covering the tensioners I have been breaking along with all other damage caused by the failures such as chain, gears and cover. Even gave me a spare tensioner to keep in the trailer so I had replacement parts to get me back on the hill. The support from Cat has been great in that sense, but still not much good to me when up on the side of the mountain somewhere and have to be towed off the hill on a brand new sled. I want a fix. And this is all I have found other then going to a full blown belt drive which in my mind is way too expensive. I know stock does not work, so I feel I have nothing to lose by trying the manual tensioner.
