K
I have a Iqr with a 600ho, Holtz front end with Fox Floats. The rear is a 151" Rmk rail with Holtz arms and Fox Zero coil over shocks.
I would seem that my sled like to nose dive alot.I don't know if that is how the IQR handle or is my suspension not set up right. I would like the front end to come up more less ski pressure, but I do not remember what I need to do to get it that way. Do I loosen up the front oil over shock or make it more stiff. How much air PSI should i Run in the fox Floats up front? Any info would help. I am a larger guy about 240 so i like the rear suspension a little stiffer for bumps.
Thanks again.
Thanks again.
