runnable carb angles?
rmking700
New member
86
4
8
34
Utah
How hard of an angle can I run my carbs on before I will start having trouble? trying to tilt my old 700 motor back a bit in its new home and will need to angle the carbs up to clear the tunnel and Jack shaft area
Dec 27, 2007
82
9
8
Calgary, Alberta
My take on it............It will lower the amount of fuel in the bowl, depending on where the float is pinned.I think the biggest headache would be trying to figure out a float level that the engine can still pull fuel from but not cause a flood condition or heat soak boil over. Obviously set the float level to begin with and try it. you may end up with a big bog..................SRXtreme
