2018 pro 155 clutching help please
Apr 14, 2008
55
Jenkins, MN
I have a 2018 pro 155 2.6 with the full slp exhaust. I have what slp recommends for clutching. I was out in big horns and am going back out in a couple weeks. I feal the clutching could be better as I had to keep adding to my weights. I am running the blue pink spring which is a 140-340 with around 65-66 gram weights and I will still hit around 8500-8550. Anyone have a setup like this and willing to share their secrets haha? Thank you in advance
t30mg
843
404
Brush Prairie Wa
That's a great problem to have.
Throw more weight in there, that's what it's for.
FWIW, I ran magnum force weights on my 18 and before it was broken in, I had to run them bare at 4k'
I would have loved to be adding weight!
Teth-Air
4,559
2,789
Calgary AB/Nelson BC
www.specified.ca
You can also run a softer primary spring if your weights are non adjustable. A 120 start and 310 or 320 finish. Lighter weights can be a bit better when it comes to clutch life and a spring is cheaper and easier to change.
Apr 14, 2008
55
Jenkins, MN
I will be throwing more weight at since they are adjustable. I have the new epi weights. I can try different springs as well since I have a pretty easy access to them. Thanks everyone for throwing out the advice
