04 sno pro 440 timing control?
sledhead162
278
35
I just bought a 04 sno pro and it has the timing control retard or advance 3°. My ? Is, it says to run straight 110 fuel. Is that at full advanced timing? Can I run prem pump at 0° or retard the timing ?
RACINSTATION
7,503
3,459
Idaho
To do it right you need to have the head relieved and then you can run pump gas. You can retard the timing and it will help prevent pre-ignition, but you need to lower the compression if you want to run pump gas.
