N
10 micron filters
Note that most of those are PAPER elements. If it's on the low-pressure side (suck side), then it's fine. If on the pressure side, it will blow out and you'll have to only use the stainess 40 micron elements. Not sure if this is the low or high pressure line, so just an observation.
Also, you might want to consider PTFE fuel line, if you can get fittings for it. More $, but might be worth it. And works with ALL fuels, even straight ethanol.
