P
Boss Noss install 2009 D8 the NPFI kit with pics
I wasn't happy with the switches that came with the kit so I cut up the harness and used the P.E.R.C. button Polaris part number 4010874 for the push button switch and had some custom stickers make. I used a single pole switch for the on/off button and mounted it on the right side of the tank covering. I'm using an HPS can so the 5LB carbon fiber nitrous bottle will fit. I removed the air horns form the air box and angled the injectors so they feed right into the throttle bodies. I changed the output on the fuel bottle so I points up, this way there will be no way air will enter the bottle when I climb strait up, and it helps with clearance issues I had. I connected all the plastic lines so if I need to work on the sled I won't have to undo any of those lines just the main nos line. I'm running Trick fuel at 114 octane with a premix in the fuel bottle.
Dustin
Dustin
