Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 04-17-2018, 07:10 PM
pete/ny pete/ny is offline
Currently: Not set.
Basic Member
pete/ny is an unknown quantity at this point
Default 2017 Assault 144-NO BRAKE LIGHT!
I just bought a 2017 Assault and find that the Brake light does not work. The Tail light does work though. I took the lite itself off and tested it and both the tail light and brake lights work. But not on the sled will the brake light work.I was told that the switch might be stuck, this is a nearly new sled and upon looking at the switch where the lever pushes ib is a sealed unit. Any thoughts on this? Thanks
Rate this post: Yes | No
  #2
Old 04-19-2018, 02:44 PM
catothom catothom is online now
Currently: Arctic Cat Proclimb M800 LTD Black Out
Basic Member
catothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond reputecatothom has a reputation beyond repute
Default
Same thing was on my new 146. Moved the brake assembly and the cluster on the bars a little when rotating it and suddenly it worked. Been okay after that
  #3
Old 04-20-2018, 09:48 AM
Currently: Not set.
Basic Member
Default Working now!
Thanks for the reply. I found that under the Master Cylinder there is a small metal plunger that the brake handle contacts to turn brake light on. Mine was stuck in and after pulling it out with a small needlenose plier and lubed it up find it works like it should.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 03 700 no tail light or brake light Thread Starter — 11mudder Forum — Polaris: EDGE Replies — 3 Last Post — 02-08-2018 12:12 AM
Thread — 2016 or 2017 Assault 144 Rear Susp Thread Starter — RusseauRestore Forum — Polaris: AXYS Replies — 2 Last Post — 03-10-2017 01:38 AM
Thread — Brake Light works Running Light Doesn't Thread Starter — ←snow∞motion→ Forum — Yamaha: 4-Stroke Replies — 4 Last Post — 03-22-2012 01:06 PM
Thread — Tail light/brake light? Thread Starter — Redd Forum — Polaris: 900 Replies — 12 Last Post — 01-08-2010 05:13 PM
Thread — 07 Brake light Thread Starter — thebri Forum — Polaris Replies — 8 Last Post — 11-14-2008 01:54 AM
no new posts
