Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 04-16-2018, 08:18 PM
Ask Yourself's Avatar
Ask Yourself Ask Yourself is offline
Currently: READY FOR 2019
Ask Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond reputeAsk Yourself has a reputation beyond repute
Default 850 Belt Drive [QuickDrive™]?
Is the 850 belt drive different from the 2018 Axys belt drive? Did the ratios change for the 850? Looking for information on a 163 2.6 track. Polaris and there gearing has drove me nuts for years. Any input would be great. Thanks...
Rate this post: Yes | No
  #2
Old 04-17-2018, 07:48 AM
damx damx is online now
Currently: Not set.
damx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond repute
Default
Same as the 16-18 axys.
  #3
Old 04-17-2018, 08:09 AM
edgey's Avatar
edgey edgey is online now
Currently: Counting the hours till I go riding
edgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond reputeedgey has a reputation beyond repute
Default
I kept my pro gears off of my 17 plan on putting them on my 850
  #4
Old 04-17-2018, 10:19 AM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
Divide the bottom gear by the top and then for 7 tooth drivers:
divide by 0.85 for 2.6" track
or
divide by 0.92 for 3" track
This brings gearing equivalent to 8 tooth drivers.
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
  #5
Old 04-17-2018, 05:42 PM
Default
What I found out today is the gearing is the same as 16-18. A 1.95 ratio is way to high. I think 2.37 to 2.52 would be a lot better for the mtns/trees. On non turbo sled. Doo is 2.37 to 2.62 cat I think is now at a 2.62. People complain about how weak the 800 pro is well it will be if all there pro axys mtn sleds are geared like lake racers. Don't care if there lighter just even the playing field in the gearing and clutch department then with that let's see what happens. I don't need to do 95 down the trail but I would love to see 55+ on the hill. Just my thoughts and experience.
  #6
Old 04-17-2018, 06:02 PM
richracer1's Avatar
richracer1 richracer1 is online now
Currently: Loving my BMP 860
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
Default
Quote:
That's just the belt drive ratio.
The final drive ratio is 2.22 which factors the 1.95 QD ratio and the 7T 2.86P drivers. Gearing down is easy, get some Pro-Ride QD sprockets, use your Axys QD belt and your gearing is into the 2.3 range.
__________________
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to richracer1 For This Useful Post:
Scott (04-17-2018), ZRP Engineering (04-20-2018)
  #7
Old 04-17-2018, 06:36 PM
Default
What's Kurt's gear down final ratio then? The QD comes out at 2.37?
  #8
Old 04-17-2018, 06:38 PM
Default
What is Pro-Ride QD sprokets?
  #9
Old 04-17-2018, 08:49 PM
sledhed's Avatar
sledhed sledhed is online now
Currently: Last ride of the season 5/25/18...
sledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond repute
Default
Quickdrive sprockets / gears off the Pro-ride chassis Pro-RMKs have one more tooth on the bottom and one less tooth on the top and fit on the Axys shafts with the stock Axys quickdrive belt, giving you a cheap gear-down. Just sold a set of those a week or so ago off my 2015 Pro for $160 shipped, may have another set for sale soon...
__________________
Snowest forums member since December 19, 2001...
15 Pro 800 Orange Madness, Kurts gear-down and clutching, Camo Extreme 2.5x155, orange ultimate bumpers, WE clickers with Raptor triple rates, FTX kit, e-start, Ultra-Q can, Holz venting
Member:Missoula SnowgoersMontana Snowmobile Association
  #10
Old 04-17-2018, 10:27 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is online now
Currently: Power Clawing the Axys....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
Default
Or quit messing around with the tiny 7 tooth drivers- and get the drive out of a 13-15 pro - now you have 8 tooth drivers ( same pitch) and a easily find gear ratio and a much flatter approach angle.
2.33 with boost @ 10 lbs is a pretty good combo-2.6 163
Most of my peeps are running the TKI system and scrapped the stock QD-
making gearing changes in the field are a snap, for daily condition changes.
__________________
Dealers for:
Silber Turbos.
GGB Exhaust.
TKI.
F-N-I.
K-Mod.
2016 Axys 3" 162 P/C Track W/Silber Turbo/K-Mod Gen III/TKI
  #11
Old 04-18-2018, 12:09 PM
Click Here to Register
  #12
Old 04-18-2018, 12:31 PM
sledhed's Avatar
  #13
Old 04-18-2018, 01:39 PM
madmax's Avatar
madmax madmax is online now
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
  #14
Old 04-18-2018, 02:18 PM
  #15
Old 04-18-2018, 02:40 PM
sledhed's Avatar
The Following 2 Users Say Thank You to sledhed For This Useful Post:
aksledjunkie (04-18-2018), mountainhorse (04-18-2018)
  #16
Old 04-18-2018, 02:55 PM
aksledjunkie's Avatar
aksledjunkie aksledjunkie is online now
Currently: Payin' the dough to play in the snow
aksledjunkie has disabled reputation
The Following 2 Users Say Thank You to aksledjunkie For This Useful Post:
mountainhorse (04-18-2018), ZRP Engineering (04-20-2018)
  #17
Old 04-19-2018, 08:29 AM
madmax's Avatar
Currently: Not set.
  #18
Old 04-19-2018, 08:47 AM
Reddragon800 Reddragon800 is offline
Currently: Not set.
Reddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond repute
  #19
Old 04-19-2018, 10:05 AM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
The Following User Says Thank You to mountainhorse For This Useful Post:
squezz5 (04-23-2018)
  #20
Old 04-19-2018, 01:28 PM
  #21
Old 04-19-2018, 01:39 PM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
The Following 2 Users Say Thank You to TRS For This Useful Post:
mountainhorse (04-20-2018), Sage Crusher (04-19-2018)
  #22
Old 04-19-2018, 05:25 PM
sledhed's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Skidoo 850 belt problem Thread Starter — Lirrew Forum — Ski-Doo: REV Gen 4 Replies — 57 Last Post — 02-04-2018 10:34 PM
Thread — G4 BELT EATER! [2017 Ski Doo 850 Rev G4 clutching/belt fix?] Belt Issues Thread Starter — NWaxys Forum — Ski-Doo: REV Gen 4 Replies — 229 Last Post — 06-10-2017 06:15 AM
Thread — 850 etec and 800 belt the same? Thread Starter — jeriziah Forum — Ski-Doo: REV Gen 4 Replies — 7 Last Post — 11-05-2016 11:12 PM
Thread — New never installed pro rmk belt, quick drive belt, and Misc in seattle Thread Starter — biggdaddy Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 10-27-2014 08:54 AM
Thread — 1 Ski Doo Drive belt. 1 Polaris drive belt and 1 Ski Doo Rear track shock Thread Starter — jtt35 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 05-23-2011 02:52 PM
no new posts
