I need a little help, My pro loses spark. Here's the story.
Day one:
Unloaded the sled and ripped up the hills with no problem for about 3hrs. Then all of a sudden while climbing a hill it loses power and stops moving, noticed the gauge cluster cuts out and the engine flutters but stayed running while. It eventually dies but fires right up and after a bit it clears up and it runs fine for about 10mins. It cut out a few more times that day but always stayed running.
Day two:
Ran as it should for about 19kms on the trail at about an average speed of 60MPH. At the 19km mark we switched from trail riding to un-groomed trail with deactivation ditches which meant a slower speed. Sled cut out and stopped running as if it were shut off. It had no spark and never did recover. Pulled it off the hill and place it in a heated shop to thaw out snow under the hood. After about an hour of thaw time it fired up. Thinking it was the Throttle safety switch, I had it turned off in the ecm and rode the next day.
Day Three:
Made it 1Km down the trail when it cut out and quit running. Didn't wait to long pulled it down and handed it to mechanic in town and rented his sled. The mechanic walked into the trailer and it fired first pull. He changed out the voltage regulator thinking that was the problem. (He is not a Polaris mechanic) just a general mechanic.
Day Four:
Fired it up, backed out of the trailer but it hesitated a couple times. Hesitated up the trail a bit. It for the most part stayed running but did act differently then before with the other voltage regulator. It did not quit until after a long pull up the hill and as if you shut the engine off just as I turned around. Waited about five minutes it fired up and I started to drive down and it quit again. At the bottom of the hill I waited about ten minutes and it fired again. Feeling it was going to act up again I went down to the trailer. It never missed a beat and ran fine all the way down.
Day Five:
Back home. Unloaded out of trailer and placed in heated garage over night.
Day Six.
Went out to look at it and test it. Stator tests OK. Tried to start it, no spark. Pulled spark plug and no spark, then spark. Put spark plug back in, no fire. give it a little throttle and it fired up. low idle. Reset TPS through computer and fired and idled fine.
Notes:
2013 Pro Rmk
The sled has no bogs when running, when it acts up it is both cylinders. It acts just like you shut it off.
Any ideas, would be greatly appreciated.
Day one:
Day two:
Day Three:
Day Four:
Day Five:
Day Six.
Notes:
2013 Pro Rmk
