Recommended Gearing
C
Clarke673
Somewhere between too dumb to quit and flat earth
Dec 2, 2007
3,138
483
83
Gardiner Montana
What are the stock gearing in the IQR's? I want ot gear my sled down but i have never been told what gears i should run. (05 IQr with 800 VES adn 151" track)
meathooker
1,655
625
Boise, ID
iirc 19/45 is stock
i went to 20/45 to get a little more track speed when it was a 121" with a 685...worked really well for boondocking and spring time mountain riding. if i was ditch banging i might want to try a 21/43.
now it's a 155 and i am leaving the 20/45. if i can't get enough track speed i think i'll drop the bottom to 43.
P
Mar 12, 2008
1,838
144
sunnyvale trailer park
I'm at 20/45. definately not a high speed trail machine, but that's not what it's built for. Unfortunately to get to the good stuff you gotta ride some road, I think I might drop to a 43 bottom see how that works.
This is on a '06 iqr bigblock 800 with a 156
meathooker
1,655
625
Boise, ID
do you have a speedo on your sled? i'm curious what track speeds iqr's are getting with the super low gearing...
P
Mar 12, 2008
1,838
144
No speedo unfortunately. Just have to go by the speeds I know I was doing on previous sleds I've owned. Last one was a d8 with 20/42 if I remember right. This one is obviously noticeably revving higher trying to keep up on the trail. The d8 would top out around 72 mph but it took a lot of flat road to get there
C
Clarke673
Dec 2, 2007
3,138
483
83
Gardiner Montana
I know my sled about rips your arms off IF it ever hooks up but with the 121 on it it never wants to hook up at all. I am assuming it tops out around 60.
Hesdale
8
18
Central North Dakota
Any information on gearing for an 800, with a 144 track? I am still running stock gearing. To make higher track speeds, would I increase the top gear? Are the drivers 9 tooth on the race sleds?
catssuk
4,853
193
Edgerton Wi.
my 05 iqr had [stock] 19/39 i used this for my 144x2 conversion pulled it no problem, sled speed with hand held gps[on a flat trail 8100 rpm] was 93 mph,i went to a 159x2 and could not get the clutches to open up so i went to a 19/41 so far it seems to be ok, i have not speed checked it yet, this is a ported, slp 05 800 moter, slp,pipe,can,stock head,v forse reeds,and there clutching.
catssuk
4,853
193
Edgerton Wi.
i have 9 tooth extroverts on mine[stock] go larger on top gear or smaller on bottem gear to go faster[just the opposite to go slower]
G
ggcustoms
837
201
NW Wisconsin
iqr gearing
Im running the short track 1 3/4 still and switched from the stock 19/45s to 23/39s for some more topend when trail riding, 22/39s are stock 600rr gears and the 23/39s are stock switchback gears I had laying around and they worked ok with the stock 76p chain, although would have been better with a 74p, Just changed today so I haven't had a chance to ride it yet. might go to 20/39s if this doesn't work well only because I have one here, after all times are tough and sledding is a spendy sport, the stock gears couldn't keep up in the straight aways or railroad beds and I ride with all long tracks, hopefully this will work, also trying the stock blk/grn spring out of my D8, time will tell, But need some damn snow!
