2007 M8 wont rev
L
leadfoot33
605
194
Prince George BC
hey guys my lil bros sled wont rev past 68-7200 he said if he holds it there long enough it will eventually clean out and go but takes a really really long time. sled has slp pipe and can combo, 40/36 helix. primary has gold spring (dont recall the weights)
things we have done, checked and replaced spark plugs, new fuel. are the power valves out of adjustment? they have never been adjusted it has been ridden about 3 times this year with no issues.
no codes have come up either
we are wanting to ride tomorrow but this started happening. any help is appreciated.
snownman
479
70
broken cable...
You need a new cable. Problem 1 if you tied them both open it would be real sluggish on throttle response. 2 the ecu would not receive the proper signal from the servo motor and would not change engine timing. IF you had a bypass plug like is used for power valve delete apps. you could make the sled run ok til you get a new cable. sorry for the bad news, but you need the p.v.'s working. also when you get the new cable adjust them to 35 mm cable showing to the bottom of the barrel.
