Upgrade to Premium
Reply
  #1
Old 09-17-2017, 10:51 AM
broke'n'nuts broke'n'nuts is offline
Currently: Not set.
Basic Member
broke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud ofbroke'n'nuts has much to be proud of
Default 2016 450fx power issue
Getting ready for second yr on bike, noticed last yr that on the trail bike pull all gears really well except 5th. Won't rev out and seems to lug quite a bit. Haven't spent any time with anyone else on similar bike/set up to ask if it's normal or not. Running a 129 yeti. Tried a few different maps with same result. So question is if this is normal or have I got an issue somewhere? Thanks in advance
Rate this post: Yes | No
  #2
Old 09-18-2017, 07:39 AM
assaultn assaultn is offline
Currently: Not set.
Basic Member
assaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond reputeassaultn has a reputation beyond repute
Default
I rode an fx for a weekend last year and found the same. 5th is pretty tall on that bike. Down at lower elevation I could get it to sing but up higher it just chugged along especially when heading up the trail climbing. I put a six speed conversion in my ktm and find it much the same in 6th. I would imagine that my 6th is close in gearing to your 5th.
The Following User Says Thank You to assaultn For This Useful Post:
broke'n'nuts (09-20-2017)
  #3
Old 09-18-2017, 09:41 AM
needpowder's Avatar
needpowder needpowder is offline
Currently: dreaming of global cooling
needpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond repute
Default Agreed
Your definitely not going to be able to pull fifth all the time on the trail. Most likely your bike is fine. How many hours on it? I have 100 on mine and it is at the shop right now getting a new piston, timing chain, valves checked etc. it's worth it to me for peace of mind even though my bike was running great when I put it away last June.
__________________
2016 YZ450fx w/16 TS LT
The Following User Says Thank You to needpowder For This Useful Post:
  #4
Old 09-20-2017, 09:16 AM
Currently: Not set.
Basic Member
Default
Quote:
I've got about 60hrs on. Had the valves checked and set around 40-45. Glad to hear it's normal. Ran against a couple of ktm's last yr in the dash for cash, had really good leads but bike couldn't pull the higher gear to stay ahead. Ran me down on the last half, time to find a bit more power or maybe monkey with gearing I guess. Thanks for input
  #5
Old 09-20-2017, 11:03 AM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is offline
Currently: What to ride............ARO or AXYS or ARO orAXYS or ARO or AXYS orARO or AXYS or ARO orAXYS
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Quote:
Maybe you can use the 5th gear parts from a yz450f
__________________
Try again
The Following User Says Thank You to Sheetmetalfab For This Useful Post:
broke'n'nuts (09-23-2017)
  #6
Old 09-22-2017, 03:16 PM
Uncle Bob Uncle Bob is offline
Currently: Not set.
Uncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond repute
Default
I see similar performance out of mine, i would like to try and get mine to get into third a little better when climbing at 7500 to 8000 feet, seriously considering a gytr head but also waiting to hear more on these ecu.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Importing a 450FX from Canada Thread Starter — hughesfoundation Forum — Snow bikes Replies — 3 Last Post — 09-11-2017 02:48 PM
Thread — Light on Yamaha 450FX Thread Starter — Snow Fever Forum — Snow bikes Replies — 5 Last Post — 01-03-2017 10:49 AM
Thread — 2016 Axys Reverse Issue? Thread Starter — chalkwild Forum — Polaris: AXYS Replies — 13 Last Post — 10-29-2016 11:05 AM
Thread — 2016 spindle fitment issue Thread Starter — b_sandgren Forum — Vipers! Replies — 4 Last Post — 12-09-2015 10:00 PM
