Upgrade to Premium
Reply
  #1
Old 09-11-2017, 10:35 PM
nwbcr nwbcr is offline
Currently: Not set.
nwbcr is an unknown quantity at this point
Default 300 intake for snow
I have a 17 300 xcw and I'm looking for info on what air intake/filter system people are using for the snow.
Rate this post: Yes | No
  #2
Old 09-13-2017, 01:15 PM
arctic@1m arctic@1m is offline
Currently: Waitin on Lane
arctic@1m is an unknown quantity at this point
Default
I used the timbersled intake on my 300 XC last year. Worked well. You'll also need an Avid carb heater, SX CDI, Pro Circuit Pipe and cut head. They rip!
I've got an extra set-up if needed.
  #3
Old 09-27-2017, 09:39 PM
jaredXwoodsman jaredXwoodsman is offline
Currently: Not set.
jaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant futurejaredXwoodsman has a brilliant future
Default
Sorry to reply to this post so late I kept forgetting to.
I ran the stock intake that KTM provided with my TSS kit on my 2016 300 for only a couple rides. After noticing how snow covered my stock setup was getting I opted to run the Timbersled filter pod but on a 45> HPS silicone hose instead. I had to cut it down to work right. But it tucks slightly into the air box and doesn't get covered with snow.
HPS info:
HPS High Temp 2.5" > 3" ID 4-ply Reinforced Silicone 45 Degree Elbow Reducer Hose Blue (63mm > 76mm ID)
Item #HTSER45-250-300-BLUE
They also carry this hose in black.
The Following User Says Thank You to jaredXwoodsman For This Useful Post:
wwillf01 (09-28-2017)
  #4
Old 10-10-2017, 09:11 AM
barefooter barefooter is offline
Currently: Not set.
barefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond reputebarefooter has a reputation beyond repute
Default
That is the way to do it. Yeti one works well too.
  #5
Old 10-11-2017, 12:47 AM
powdermuncher powdermuncher is offline
Currently: Not set.
Basic Member
powdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond repute
Default
To cover the track like Yeti or camso helps a bunch as well time for TS and the rest too figure out that no one needs or likes a wet butt and air filters covered in snow. Just for the lack of a cover over the track--oh forgot they want to sell you new Klim gear to keep your *** dry
That said I always run pod filters like that to avoid issues.
  #6
Old 10-11-2017, 12:50 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: What to ride............ARO or AXYS or ARO orAXYS or ARO or AXYS orARO or AXYS or ARO orAXYS
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Here is an easy way to do that.
My pod filter is in the front though.
__________________
Try again
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Setting up the 300 XC for snow Thread Starter — GlennRMK Forum — Snow bikes Replies — 84 Last Post — 02-11-2017 07:13 AM
Thread — KTM 300 TSS Intake install Thread Starter — jskattum606 Forum — Snow bikes Replies — 13 Last Post — 11-23-2015 08:46 PM
Thread — in search of ideas for ktm 300 air intake Thread Starter — stevie boy Forum — Snow bikes Replies — 10 Last Post — 01-19-2015 09:28 AM
Thread — 14 Pro 800 155, snow check, 300 miles, extras Thread Starter — fastlane Forum — Polaris (Swapmeet) Replies — 0 Last Post — 04-02-2014 07:59 PM
Thread — snow in intake Thread Starter — Grey44 Forum — Polaris Replies — 11 Last Post — 03-13-2009 11:34 AM
