Upgrade to Premium
Reply
  #1
Old 09-03-2017, 09:09 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: ARO or AXYS or ARO or AXYS or ARO or AXYS or ARO or AXYS or ARO or AXYS
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default Lowering a Timbersled kit. And copying the aro a little.
So in the interest of putting my drivers behind the bike a little.
Deep snow performance is my main goal.
Also I want to be able to flat foot on concrete.
Cut and tipped down the front of the frame 2".
Welded a tube inside to bridge the gap.
Cut 2" vertically out of the spindle to level it out.
__________________
Try again
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Sheetmetalfab For This Useful Post:
vega350 (12-20-2017)
  #2
Old 09-03-2017, 09:11 PM
Default
__________________
Try again
2 out of 2 members found this post helpful. Rate this post: Yes | No
Norma Stitz (10-24-2017)
  #3
Old 09-03-2017, 09:14 PM
Seat concepts seat is 1" taller than stock in the low point.
2" taller in the wide point.
So many snowbikes are low on the rear of the seat so I thought to avoid this.
It was actually foam and cover from a ktm seat concepts tall that I found locally for cheap and cut down to fit.
At 6'2" i need the peg to seat height for comfort when sitting.
__________________
Try again
  #4
Old 09-03-2017, 09:49 PM
Tucked up nicely.
12" ground clearance.
__________________
Try again
  #5
Old 09-04-2017, 12:05 AM
Default
7/8 long stainless tube extensions for my pegs.
__________________
Try again
  #6
Old 09-05-2017, 10:37 PM
TreewellDweller's Avatar
TreewellDweller TreewellDweller is offline
Currently: Not set.
TreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond repute
Default Lowering Seat Height
Just curious, instead of trimming the ski spindle, could you have just slipped the fork tubes up a couple of inches?
  #7
Old 09-05-2017, 11:46 PM
Default
Quote:
Yamaha forks taper pretty quickly.
I probably could have gotten 1" max.
Plus the skid modification was permanent so the lessened spindle twist forces was a side benefit.
__________________
Try again
  #8
Old 09-16-2017, 02:22 PM
J&L Snowhawk's Avatar
J&L Snowhawk J&L Snowhawk is offline
Currently: waiting
J&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond reputeJ&L Snowhawk has a reputation beyond repute
Default
You get more drag through the snow like that At your height I can't see how you need shorter than stock
__________________
check out my website www.garysengine.com
http://stores.ebay.com/garysengine
MOTO-TRAX DEALER
Dealer for Dobeck Performance. Rekluse clutch,snowbike bypass thermostat, custom intakes & engine shrouds
SNOWHAWKSURVIVOR
https://www.facebook.com/pages/Garys...97829540418236
SNO-RKT video https://youtu.be/pi3huljPBhU?list=FL...HPT_KSr3L6SPpw
  #9
Old 09-16-2017, 11:06 PM
Default
Quote:
You tried it?
And noticed the 2" lower made more drag?
You're right I don't need it shorter.
But i do know how low speed mobility suffers when the centerline of the drivers is below the skid plate.
I cant see how higher speeds would have anything but a good effect from this mod in that stuffing the track in a hole doesn't have a vertical approach angle at the front of track nearly stopping forward movement.
(I noticed this on the 800r bike I built)
Especially with a tiny bit of crust. Would almost throw me over the bars.
But the proof is in the pudding I suppose, let me know if I'm way off from your experience.
__________________
Try again
  #10
Old 09-19-2017, 10:06 AM
CATSLEDMAN1 CATSLEDMAN1 is offline
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
  #11
Old 10-24-2017, 09:57 PM
wellfed777 wellfed777 is offline
Currently: Not set.
wellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to wellfed777 For This Useful Post:
  #12
Old 10-24-2017, 11:11 PM
  #13
Old 10-27-2017, 10:21 AM
mrsnow mrsnow is online now
Currently: Not set.
mrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond repute
  #14
Old 10-27-2017, 04:45 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Old ts vs. Aro Thread Starter — damx Forum — Snow bikes Replies — 5 Last Post — 06-01-2017 02:21 PM
Thread — 2013 Timbersled ST120 snow bike kit and 2moto kit Thread Starter — Varmit243 Forum — Snow bikes Replies — 1 Last Post — 03-16-2016 07:57 PM
Thread — Heard BRP might be putting cat out of business for copying parts???? Thread Starter — zx7thrills Forum — Arctic Cat: Proclimb M Replies — 7 Last Post — 12-24-2011 11:48 AM
Thread — Name game....Who's copying who? .... Who cares? Thread Starter — Mafesto Forum — General Snowmobiling Replies — 2 Last Post — 03-27-2011 07:33 PM
